- Mar 21, 2013
- 4,064
Some comments about the EL700 and touch probe. First, the shaft on the touch probe is .393", which means it doesn't fit in a standard 3/8" R8 collet. I think something like 25/64" is about the closest. Then, I remembered the ER-32 collet chuck I bought (no comments about forgetting tools please...), and vaguely remembered someone here commenting about the greater range of sizes these collets will grab. It's a snug fit, but it fits.
The touch probe default ships with the break-away tip, although a steel one is available. Installed the tip, and then started thinking about how to calibrate/center the .118" tip to spindle centerline. This is my first experience with a touch probe, so this is all new to me. Finally got the thing more-or-less centered (less than half a thou) and started trying to figure out how to use this thing. I was using a gauge block to determine the accuracy of the touch probe and DRO system while capturing the length of the gauge block in the x-axis. Problem was, it was off by just over 3 thou, plus or minus. What? I saw a little icon in the lower right of the display that showed a the touch probe tip next to a vertical surface (the manual for this thing is terrible...no reference to this anywhere) but it appears to be where you input the diameter of the touch probe tip. I think. So I started changing the value, and sure enough the results of my measurements started changing. But, I was having to put in smaller tip diameters to get the system to read out within a few tenths. Hmmm...
Then I tried to just capture a datum in X. Way off... Now I'm getting frustrated so I called it quits for the day (yesterday evening). Then as I'm finishing up my coffee, I go back and re-read this one-page commentary about the touch probe. Apparently, you have to position the rotation of the touch probe so that moves the 3 sensors at the same time, or in the proper order. Huh? That's all the paper says. Then on the back it shows it (touch probe) dis-assembled with some comments that the factory puts too much grease in there and you should take it apart and clean it for proper operation. Great. This thing is a real PITA to get aligned, and it looks like I have to do it all over again.
So today I'll attempt to start over and hopefully get some better results. If not, tomorrow will require a phone call to DroPros.
Anyone here have any experience with these things who could offer some suggestions to a noob?
