I posted in this thread about my motor going TU. I received the replacement this A.M. I was shocked to see the distribution block when I removed the cover in order to remove the connections to transfer them to the new motor.
What I found:
I'm hoping against hope that I can get by with changing the terminal block right now so I can get a couple of jobs out today. The problem I've encountered is they're wired differently. The motor that's on the lathe now has been working since day 1 with the blue wire taped off and just hanging there.
The blue wire not connected:
This is the way the new motor is wired. Blue wire connected to the terminal block:
My electrical skills are right up there with my skills as a neurosurgeon, as in not my gig, at all.
What would the electrically enlightened suggest I do? My gut says to put it back the way I found it. On the other hand the last thing I need is to see smoke & sparks.
What's a mother to do? Suggestions?
Thanks,
Dale
What I found:
Thanks,
Dale
