- Jul 27, 2021
- 221
I had posted some questions earlier about what lathe to get for my first lathe and I pulled the trigger on an 8x16 lathe that is equivalent to the eBay variety. I bought it off Amazon with the hopes that should things go really poorly I would have a better shot at some level of recourse, but who knows. Someone on that other thread asked that I post about my experience with this lathe so this thread is that effort. I expect it to take a few weeks to get this lathe up and working in some sort.
Well a big crate arrived today and it was in pretty pristine shape! This was surprising to me seeing as it came across the ocean, went across the US, and then came back to California. There were no signs of damage on the crate apart from a slight misalignment of one of the skids on the bottom.
When the top was removed it revealed everything inside was apparently in good shape. Styrofoam blocks at each end were intact with no apparent damage. So far so good!
However, when the plastic was removed it was clear that a bunch of stuff was missing. This was supposed to come with two chucks (3 and 4 jaw), the ubiquitous useless toolbox, some tooling, etc, but none was to be found. There is no chuck at all on the machine - having never bought a lathe I was not sure if they shipped with them on there or not. I have inquired with the seller via Amazon as to the whereabouts of these items and hope to hear back soon. Perhaps those items are in a separate shipment.
This has all the cheap lousy features that many complain about but for $1K what more can I ask for.
This model was supposed to include a 1.5HP brushless DC motor. This larger motor was the main reason I chose this model so it had better be in there! I have to wait until I can get some help to lift it up onto my bench to see if that is actually the case. I have access to an engine hoist from a friend if I can't get my college age son to give me a hand. Everything is covered in the usual oil and needs a thorough cleaning. The compound and cross slide are poorly adjusted and probably full of gunk too, so they will get torn down and cleaned up.
With any luck this will work out OK. As I mentioned in the previous thread the one thing I know for sure is that I will learn something useful in the process.
More to follow....
Tom
More to follow....
Tom
