[4]
New Pm 727m Mill
[3]
[10] Like what you see?
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#1
Anybody else taken a look at the website lately and seen this new mill? It appears to be a RF45 style variant with a slightly smaller table. 15" of x travel, 8.25" of Y travel, 16" of Z travel, with 18" spindle to table!! And, it is a 110 volt machine. Looks very appealing for $1,800. I have been wanting a PM25MV for a while as it is great reviews, lots of travel, and a good sized table. Now, I am very torn between the two offerings. I think the 727 would do a better job with hogging and heavy cuts. What is a guy to do....
Dan_S
Aug 26, 2013
967
Likes
837
#2
I notice that as well.
It's bigger than the PM25, but still a lot lighter than the pm45/932 475 lbs vs 1100 lbs.
I Think it would be better than the pm25 in all respects except for the 25 being variable speed.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,429
Likes
1,414
#3
My first thought was 'PM25 on steroids'.
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#4
Well, I am going to try one of the new 727's. I will report back ASAP! The mill is in stock, which is always a plus. This looks to be a fantastic hobby mill and should fit my needs very well. Now the questions is whether to rebuild my existing bench to insure it will handle the extra weight, which will allow me to put it in the same place as my little X2, or to leave it free-standing on the factory base???
mksj
Jun 12, 2014
1,971
Likes
2,388
#5
As Bill mentioned, PM25 on steroids (like that). Would go with the stock base since it comes with the mill, and has a nice catch basin. Nice balance of size/features for its size and runs off of 120V, which is a plus if you do not have a 240V circuit.
JR49
Mar 20, 2014
430
Likes
196
#6
I too, have been looking at this PM 727m. Never owned, or even used a mill before, so the only info I have is what I've read in the forum. Square column, a big plus, 18" spindle to table big plus. I think the table size, and "work envelope" (just learned that term here) will suite my current and future needs, and the size will fit my space nicely. The things that I have no knowledge about, and would appreciate advise on, is about it being a geared head with 6 speeds from 115 to 1700 rpm. It says gears are "hardened and ground steel gears", so that sounds like a plus, but will only 6 speeds and max speed of 1700 limit this mill? Thanks for any advise on this, JR49
wrmiller
Chief Tinkerer
Mar 21, 2013
3,429
Likes
1,414
#7
My PM25 came with a similar stand and for me it was too low to the ground, too narrow, and that little chip basin isn't really wide enough to catch much (it does, just not as much as I'd like).
But that was my experience. Yours could vary. :)
wrmiller
Chief Tinkerer
Mar 21, 2013
3,429
Likes
1,414
#8
Some of us have gotten spoiled by having variable speed (I gutted El Hefe and put a variable speed/belt drive on him as well), but is it necessary? No. And the upper rpm limit should do fine for most applications I would think. Just my opinion. :)
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#9
Bill,
Everything that I have read says that the factory stand will be too low. Even if I use it, I will need to look into raising it up a bit. That is why I am leaning towards overhauling my current bench. I am sure I will slide the chip pan underneath it as I have future plans to add flood coolant.
compsurge
Oct 27, 2014
272
Likes
32
#10
The speeds are likely plenty for manual operations. Higher speeds start to require faster feed rates and more efficient coolant and chip clearing. If you can go for the larger PM-932/940 mill, definitely consider it as well. Definitely examine the actual work envelope travels of the machine versus what you intend to use it for.
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#11
My work envelope is actually rather small. Mostly gun-smith type work and miscellaneous hobby work. However, my trusty little X2 just doesn't have what it takes for steel. For aluminum, it works great. At first I was thinking of selling my X2, but the more I think of it, it will make a nice little second op machine for aluminum or perhaps a decent little drill press, which is something I don't have.
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#12
Oh, by the way, I ordered the 727 yesterday and it shipped out yesterday afternoon! It looks like I will have possibly tomorrow, or Thursday at the latest. And yes, there will be plenty of pictures!
compsurge
Oct 27, 2014
272
Likes
32
#13
Congrats! I look forward to seeing it!
brav65
Sep 24, 2014
925
Likes
496
#14
Can't wait to see it set up. Congrats!
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#15
Well, I take delivery tomorrow between 11 am and 4 pm. Rather than starting a new thread, I will use this one as the title works well!! Expect some pictures tomorrow night.
mksj
Jun 12, 2014
1,971
Likes
2,388
#16
Looking forward to your pictures and review, I think this model hits a sweet spot for its size and specifications. Matt is one of the few vendors that seems to be able to evolve his machines through the years. You still might look into building a base for the stand if you need the additional height, it looks quite substantial.
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#17
It's here! Already started uncrating. Everything is packaged well, just as expected. I have already done some preliminary measurements and it looks like I need to raise the stand about 5". I'm going to use some lumber to experiment with, then I will build an adjustable stand. 20150903_130327.jpg 20150903_131323.jpg
JR49
Mar 20, 2014
430
Likes
196
#18
Looks great 3d, I'll be watching this with much interest. Please post on every bit of your experience with this mill, as I've pretty much decided that this model is just right for my needs. As mksj said it fits nicely between the PM 25 with 13" spindle height and PM 932 weighing 1100 lbs. It'll be at least a couple more months for me, as I'm currently having daily radiation treatments, which will last another 2 1/2 months. BUT HEY, talk about turning a negative into a positive---my incredible wife agrees that a mill would make a nice "end of radiation treatments" gift ! So, thanks for all your future 727m posts, and remember there is no such thing as too many pics ! JR49
wrmiller
Chief Tinkerer
Mar 21, 2013
3,429
Likes
1,414
#19
That's a pretty nice looking mill you have there Sir!
I too am looking forward to your impressions, and of course more pics. :)
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#20
I'd send it back. Your Chinese plywood has a big void in it. Before anyone starts giving me a hard time, the OP & I are good friends.
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#21
Well guys, it has been a long afternoon. As expected, everything was packaged well. The fit and finish of the machine was great; it was right on par with my 1127vf-lb lathe I got back in January.
Uncrating was they typical chore. They do a really good job at the factory of crating these things. Once I got the crate all stripped down, I took some quick measurements of the stand and approximate height to the table. The stand is 27" tall, and the table sits about 8" above that. That is a little low for me. I whipped up a temporary stand from 4 ×4's and 2×4's, that gave me 5" more height.
I hoisted everything up into position (except the chip pan which I forgot in my excitement) and bolted it all down. The first thing I noticed is that the y axis was almost impossible to move. It was bound up tight. I inspected the tapered gib and it appeared to be a little long. I sanded it some using the mill table as a flat surface. Then I filed the notch for the gib adjustment screw a little deeper as I realized the screw on one end was only about 2 threads in. This gave me more peace of mind that the screw would hold. I also turned a spacer for the other side adjustment screw as it was bottomed out and not engaging. This allowed it to actually make contact and secure the gib.
The only other issues were simple. The t-slot bolts included in the tool box were too wide for the slots, and for the slots in my new 4" vice. Ground those down to fit and filed the slots on the vice accordingly. Then I noticed that the draw bar was not threaded long enough to fully draw the R8 collets into the spindle. I slapped a couple of washers on there for now. I plan to turn a bushing this weekend. At the same time, I found that the collet wouldn't actually go into the spindle. I remembered a thread on here where Matt commented about simply backing out the small screw in the side of the spindle. I found that screw, removed it, cleaned it and the hole, and put it back in with some blue loc-tite and adjusted it so the collets would slide right in.
The left hand knob on the table had a bit of slop in its engagement and every time I turned the right side know, the left knob made a clunking sound as the handle went over the top and the weight shifted. I shimmed that with some aluminum foil folded over a few times. To me, all that is minor stuff. It is a Chinese machine after all.
With all that said, I did mill some bar stock just a few minutes ago just to see what she would do. Man, it is a beast. My frame of comparison is a little X2 mill, so the bar was not set very high. It plowed through the steel at .030 deep with a 7/16" hss end mill at 600 rpm. I know that isn't a massive cut, but the X2 couldn't even dream of that cut.
The thing that will take some getting used to is the sound of the gears. My X2 had a belt drive. But, this mill isn't really loud at all.
I am very happy with my purchase. I think that this size machine is perfect for a hobby guy like me that doesn't have the room for a full knee mill. It should serve my purposes very well.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,429
Likes
1,414
#22
Sounds like you had a few of those 'Chinese things' to take care of, but it didn't sound like you ran into anything major. I've had similar issues with every machine I've ever owned but I was up and running a lot faster than others I've witnessed having to refurbish or restore a used machine. Of any parentage.
My PM25 will easily take a .25" deep DOC with a good quality endmill (I might use a rougher for that, depending upon the material). I had similar experiences when I stepped up from my LMS mill to my PM, and then from my PM to my CO 12z. Have you stopped grinning yet? :)
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#23
Nope, definitely still grinning!! I have a couple of new cobalt end mills that I got recently and have waited to try out when I got the new machine. I plant to see what a fresh sharp end mill will do this evening. I actually did make myself go to bed last night right after my update. My buddy Lee (lpeedin on here) was teasing me today that he knew I would end up doing some machining before bed, one way or another!!
The big things I have to do now are just to fab up a steel adjustable base, install that, and put my chip pan on and I am all set. I will fine tune the tram over the weekend too as I can tell just by milling that the left side of the end mill is cutting a little more than the right. I will also probably go ahead and do an oil change since I did a spindle break in yesterday and did some milling with it.
So far, it is everything that I thought it would be.
bsmith918
Newbie
Feb 8, 2015
7
Likes
3
#24
I'm trying to decide between this and the PM-25. This will be my first mill and I will be using it mostly for gun related machining and any other small projects. anybody have an opinion? I can't wait to see some more pics.
wrmiller
Chief Tinkerer
Mar 21, 2013
3,429
Likes
1,414
#25
I do mostly pistol/revolver work, with some rifle mixed in. My PM 25 would do most things I need of it, but if the 727 had been available at that time, I would have opted for it instead as it lends a little more mass/rigidity for when you're milling on forged slides and other similar operations.
My experience has shown that much can be done on smaller machines, but if you can afford the space and money, bigger does work better in many cases.
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#26
Well, I decided today was "tram the mill day" and what a day it was. I noted that when milling, the pattern favored the left side of the cuttet, meaning the spindle was tilted to the left. So, I went to work.
First, I trammed the head to the column. Then, I removed the column from the table with my trusty gantry crane and inspected the mating surfaces. There was no grit, paint, sand, or anything in there, just some hand scraped mating surfaces. I wiped everything down and reinstalled the the column.
After that, I checked the head to table alignment and noted that I was still tilted left about .005" over 7". So, I re-trammed the head to the column, since I just lifted it with the crane. Then I check the head to table again and I was still .0045" off. So, I loosened the 4 bolts on the column mount and tilted it to the side and ended up using a total of 16 pieces of aluminum foil to shim it. I got it to within .00075. I milled a couple passes to check and the pattern was still favoring that left side, but not nearly as severe. I plan to add 2 more pieces of foil tomorrow which will hopefully get it within .0001".
JR49
Mar 20, 2014
430
Likes
196
#27
3dshooter, or anyone who knows, exactly what is involved in tramming the head to the column ? Thanks, JR49
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#28
Head to column is the same is head to table, except you put your indicator base in the column and use that as your reference point. This insures that you are setting the rotational axis if the spindle in line with the travel of the head up and down the dovetail.
Once you know that is good, then you move your indicator to the table. Now you arw. Heckling the relationship of the spindle relative to the table. This is when you would need to shim the column to correct misalignment. Having the head square to the table is good, but it if the column is moving up and down at a tilt, there will be a shift in dimensions laterally.
I just went out and checked mine again two times amd it appears that I am much closet than I thought. I figured it this morning at less than .0005" to the left. I am going to just bump the head and mill passes until I get that perfect circle pattern in the surface. When I mill in the y axis only, I get those perect circles. Nod is good. But, there is still the slightest lip on the left edge that is visible and can be felt with a fingernail.
lpeedin
Active Member
Apr 22, 2014
427
Likes
295
#29
Yep, you lay awake half the night (after checking for ticks) thinking about the tram on your new toy. Hope to get over there tomorrow to check it out.
JR49
Mar 20, 2014
430
Likes
196
#30
So,. lets see if I've got this right. You put the magnetic base on a solid, non-moving part of the column (like behind the dovetail, on the side. Then you set the indicator plunger on the side of the head, and run the head up and down, to see if the needle moves. If it shows movement, what would you adjust, to make it right ? Thanks, JR49
[6]
[5] [7]
