- Apr 8, 2021
- 138
Hello.
I have a small milling machine (70 kg) with brushless motor 750w and morse taper MT2. I have bought a milling arbor for circular blades 16mm internal hole diameter.
But I have no idea what is the best outer diameter and thickness for the blades. I use the milling machine for hobby, small parts of aluminum or mild steel.
I know wthere is a lot of options, but for general purpose what diameter and thickness should I buy to start?
Thank you
Best regards
Thank you
Best regards
