- Jan 28, 2020
- 193
Joe Martin, the founder of Sherline Products, provided the following answer to the question, "How big a part can I work on?": "The physical size limitations of any machine are easy to determine from its published specifications, but what does the hardness of the material you wish to turn do to those numbers in the real world? A good rule to remember when it comes to purchasing any lathe is to take the average diameter you plan to work with and multiply that times 3 for free machining materials and times for 4 for tough materials like stainless steel. If the materials you plan to work with are free machining (aluminum, brass and free machining steel), you will be pleased with a 3.5" lathe like the Sherline as long as the average part you make is approximately 1" (25 mm) in diameter. Wood and plastic are so easy to machine that only size limitations need be considered. I don't mean to imply that you can't machine a 3" flywheel, but if you are planning ..." - page 267 of Tabletop Machining: A basic approach to making small parts on miniature machine tools, by Joe Martin.
I watched the two videos of Clickspring making a die holder for the Sherline tailstock. I think that the die holder can be made using a Sherline lathe and mill. Clickspring started with 1.5-inch diameter aluminum bar stock. The swing-over-the-carriage of the Sherline lathe is 1.75 inches.
Edit: the remainder of Joe Martin's answer
"... to consistently make parts of that size, you will probably be happier with a larger machine and more horsepower.
Removing large amounts of metal on a small machine takes time. If you have lots of time, the size of the part is less critical. Users of any machine are happier with its performance when they are not consistently pushing the limits of its capabilities. If you usually make small parts well within the capabilities of a 3.5" lathe and every once in a while need to turn a part sized near the machine's limits, you will be very satisfied wit that lathe's performance.
A vertical milling machine is capable of holding larger parts than a lathe because the part is held and only the tool turns. It also has a much longer table throw (X-axis travel) than a lathe. On a Sherline mill with the addition of the horizontal milling conversion, surfaces up to 6" x 9" can be machined without moving the part. This is a very large machinable area for a tool of this compact size."
