Some good points about the DRO
From previous posts, I understand that Splat is a newbie to this machining thing.
IMO, a newb, should learn basic things first. That would be learning to read dials, dealing with back lash before getting involved with DROs. The power feed/feeds would help him get the work done , without working him so hard. If the power feed was to crap out, well then just turn the handles. The mill will still work as normal, and the job will still get finished.
Not learning basic things like how to use your dials, and dealing with the machines back lash is taking a major leap past basic learning skills. Think about what will happen when his DRO has a problem. What then? Does he shut the machine down, and wait till he repairs the DRO? Now don,t get me wrong here, Im not against DRO,s, I have a 3-axis Newall on my mill. But I learned the basic stuff first.
Side stepping this basic learning curve is not such a good idea.
One of the first things to learn, is how to run your machine, and learn these steps.
Im allso one of those guys the firmly believes that on a lathe for instance, the newbie should not be using a 3-jaw chuck. He should learn basic,s, like how to dial his work in properly. Only when he has mastered this, should he be using a 3-jaw. Simple way of thinking, what happens when he must remove the work piece, and rechuck it, or turn it around? Thats when a operator would be wishing he learned to dial in a 4-jaw.
Thes are basic,s guys. One should think it over before deciding to side step the learning skills, thinking he or she doest need them. Once basic skills are mastered, then the bells and whistles are a great addition.
Something has to be said about, you walk, before you run!
