Not just accuracy (I've seen specs, the iGaging units can be several thou" out over a few inches...), also functions -.the full specification DROs will convert.between diameter and radius/depth of cut, have tool offset/cutter diameter memories, hole circle layout and taper / angle functions, all kinds.
Some can be surprisingly useful - picture making an index or dividing plate for 127 holes.so you can cut a metric transposing gear: stick the.blank on the.mill table, use.the DRO centring function in x and y to locate the centre of the plate, drill centre hole; zero the DRO and hit the hole circle.key and follow the prompts.for radius.and.number, it resets the display and you crank the handles til it reads zero-zero and drill a hole, hit next, repeat, until you have all your holes drilled to the accuracy of.the.scales (potentially 0.0001 to 0.0005"), 10-20 minutes total, I'd guess... Dividers and layout blue, anyone?
All the iGaging ones are is none too accurate digital dials, effectively.... You could do the same plate with 'em, first calculate hole positions, spreadsheet? Then read the printed table, one set of x and y at a time, make sure you don't miss any or transpose/misread any numbers...
Dave H. (the other one)
