I do but the feeler right next to it is .025" I pair them up and fold them as a pair.I didn’t know they made feeler gauges Half the size of a human hair.
What’s aluminum foil?
Wait, I’ll check.
My heavy duty Reynolds is .001”
I don’t imagine you fold these up like a jack knife?
I wouldn't mill the table. At least not before nailing down the root cause. A loose gib can cause the table to tilt as you move the table to an extreme position making it look like it is out of tram. If you fly cut the table, you could be introducing a curvature.38super, It is not a 2 in 1 type.
Mill/drill press.
I think I may have found some of my problem.
I put an indicator in the quill and trammed the table on the X axis at the middle of the table. Within .001" or so.
I trammed the Y axis, it is within .002" or less.
I trammed the table in 8" sections and the numbers were all over the place.
I had this table machined when I got this mill about 3-4 months ago.
Can anyone give me a good reason why I should not fly cut the table.
Thanks for the replies,
Dale
Milling machines (and surface grinders) can give inaccurate readings when a indicator mounted to the spindle area is testing the table (or mag chuck on the surface grinder.) Because the tables of these machines often overhang the supporting saddles when at the ends of their travel, the table and the saddle get worn (or loose) in such a way that the table droops while moving to the ends of the travel. Looked at from the operator's side while standing well back from the machines, a table with this common type of wear is traversing a large radius, close to circular curve as it moves from end to end. The indicator, reading directly below the spindle, will not properly see that the axis is not flat, because it is always reading on the high point of the circle. Another method must be used to test the table or mag chuck for flatness, and to create work that has a flat surface in the table travel direction. Or, the machine must be repaired so the ways are no longer curved or loose. This issue is quite common, but little known or compensated for.Actually, tramming should test only one thing; how close to perpendicular is the spindle axis to the ways of the mill. To check if a table is true to the ways, I mount an indicator to the head or other external surface and sweep the table buy moving x and y. If the table surface is parallel to the ways, the indicator reading will be constant. If it is not, there can be two causes, the table surface is parallel to the ways or the table is lifting due to the clearance. Tightening the gib or locking the table should determine which ( it could be both).
That is why I suggested not milling the table.Milling machines (and surface grinders) can give inaccurate readings when a indicator mounted to the spindle area is testing the table (or mag chuck on the surface grinder.) Because the tables of these machines often overhang the supporting saddles when at the ends of their travel, the table and the saddle get worn (or loose) in such a way that the table droops while moving to the ends of the travel. Looked at from the operator's side while standing well back from the machines, a table with this common type of wear is traversing a large radius, close to circular curve as it moves from end to end. The indicator, reading directly below the spindle, will not properly see that the axis is not flat, because it is always reading on the high point of the circle. Another method must be used to test the table or mag chuck for flatness, and to create work that has a flat surface in the table travel direction. Or, the machine must be repaired so the ways are no longer curved or loose. This issue is quite common, but little known or compensated for.
