- Oct 20, 2014
- 495
Hi All,
Cut my finger while rummaging in a drawer for a T handled hex wrench. Stopped work right then and there, and went to the big box store for a 4x8 sheet of pegboard, furring strips, and 2 packs of pegboard organizers.
Got home, unloaded the truck.
Then I volunteered to help my wife decorate.
Then I folded and put away 2 loads of laundry.
Then I got my big pot 'o beans going with the ham bone from our Thanksgiving day ham. (oh, yeah!)
Then I took out all the garbages.
Then I sat in my shop, had a beer, and smoked a cigar while I stared thoughtfully at the wall for awhile.
An hour later, I had a 2'x8' pegboard mounted on the wall behind the lathe. I cut the board in half, because I'm short and wouldn't be able to reach the top half over the bench anyway. The other half will go above my regular workbench.
Then I organized my organizers, and organized my lathe stuff. Now I'm happier. Things are within reach, organized, and clea...uh... well, two out of three....
The metal cabinet the lathe is currently on will be going away. I need to build a heavy wooden 8' bench for the south bend I'll be lugging home after the year end. It and the Taig will share the bench and pegboard. Stuff for the Atlas horizontal mill occupies the far left of the pegboard, but most of it is still in the totes you see on the far right. I store my extra organizers on the pegboard, out of the way. If you use something repeatedly, it's only a moment's work to grab another hook and put that tool in a convenient place. I find if I have to dig through drawers for the organizers, I'll neglect to use them at all.
Ignore the electrical disaster at the top of the pegboard. I had to remove a florescent light to put up the pegboard, and the resulting lashup is extremely temporary. As in, it'll be fixed tonight. I should have proper electric in the shop sometime around the beginning of this coming year.
Here's my Atlas horizontal mill and little Horrible Freight grinder I use for touching up HSS tools.
No beef about the non-Atlas pulleys, please. Eventually I'll put something less "redneck Engineered" on there, but for now that's all I got. It works, and works darn good with a DC motor. Speed control is the grey box holding up my apron and cigar. It's shared between the Taig and the Atlas. The Atlas sits on a discarded Grizzly mill stand, with a home-made wooden top of laminated 2x4's. It's solid and really helps with the vibration when running. The funky looking widget in the bore for the overarm support bar is a mount for my Taig spindle to do light vertical milling. One of the projects in the totes is a dedicated vertical spindle for the Atlas, using an old Taig spindle I have on-hand. Should be a bit more rigid than the current vertical attachment.
I use the little grinder for touching up HSS tools. I actually use a Dremel with a fibre-reinforced cutoff wheel to shape the HSS. Cuts faster than the 6" grinder. I then refine the shape on the 6" grinder, sharpen it on the little 3" grinder, and hone it on a diamond hone.
I use the little deburring wheel on the HF grinder quite a bit too.
I'll post pictures of the rest of the workshop as the cleanup progresses. It's been a general storage area for nearly a year, and I'm sick of not having a clear place to do what I want to do. Need to nudge my buddy about cleaning out his garage so I can get rid of a whole bunch of crates of equipment he's storing here at the moment.
FWIW, my shop is an old 50' extra-tall refrigerated semi-trailer. It's insulated (barely), has a high ceiling and a heavy-duty wood floor. Bit narrow, though. I've got it cribbed up on PT 4x4's, and just waiting on my brother in law to get time to come run my electric and whatnot.
