- Oct 20, 2014
- 495
Got some work done this evening. Cleaned up the shop a little, and while I had daylight, I cut some pieces for the workbench. Then it got dark, and I brought the saw in. And couldn't help it. I started assembling the bench.
It's all 2x6 construction, plenty of screws, lots 'o glue. Heavy as hell to boot.
Only the three rightmost planks are screwed down, the others aren't yet. I need longer pipe clamps to get the job done. There's also a sheet of 3/4" hardwood plywood going to get screwed down (from underneath) and glued to the planking. I have yet to get the 2x6's on the bottom to support the shelf, but those are going to be purchased tomorrow along with the plywood. With luck, I should have the lathe mounted this weekend and making chips next week!
I know some will scoff at the idea of a wooden workbench, but my shop is a semi trailer, with a wooden floor. The whole thing can twist slowly as it settles, and the bench is about as flat as I can make it. Besides, that bench weighs a whole lot now, and it'll just get heavier as I add more wood. I think it'll be acceptable for a SB9A lathe and a Taig lathe.
And yep, I know the corner of the rightmost board looks high. It isn't that far out of level. The board I used across the short end of the bench was split a little, and I put the split at the top, where it wouldn't cause an issue with glueing/screwing the leg on square.
You can also see the empty junction boxes for electric. I won't have any issues finding somewhere to plug something in.
Lastly, if you don't have a little cordless impact driver..... get one. My little Ryobi 18v impact did an incredible job sinking a whole ton of screws without any fuss or a single stripped screw head.
