[4]
Oh my! Enco surface grinder, getting tighter in the shop
[3]
[10] Like what you see?
Crank
H-M Supporter - Gold Member
Aug 16, 2017
107
Likes
169
#1
While trolling around the interwebs, I stumbled on a listing for an Enco 6 x 12 surface grinder. They were asking $350 so I sent a message. It was still available and I went to look at it. I was expecting a 240V 3ph machine, but it was a 115V 1ph. I heard it run and I offered $300, he said yes. Lousy timing with the space issues in my garage, but a deal doesn't wait.
Mark
Ulma Doctor
Infinitely Curious
Feb 2, 2013
181
Likes
4,746
#2
man, i was looking for the exact same type of machine and you found it!
lucky dog!!! :drool:
Crank
Aug 16, 2017
107
Likes
169
#3
Sorry Mike, like I said wasn't the most appropriate timing, but I wasn't going to let it get away. The bugger is filthy but shows minimal wear. I'm going to get a new ON/OFF switch, the original is a bit sketchy.
Mark
Z2V
H-M Platinum Supporter ($50)
May 10, 2017
688
Likes
637
#4
Good find, I’m sure you will be able to shuffle things around to make it fit in the garage. Congrats
Crank
Aug 16, 2017
107
Likes
169
#5
Z2V,
I appreciate your optimism, if gets any worse, I'm going to need to use a parallel dimension. LOL!
Mark
Z2V
May 10, 2017
688
Likes
637
#6
I don’t have floor space for another 5 gal bucket in my garage but if I come across a deal like that creative thinking would have to take over!
Ulma Doctor
Infinitely Curious
Feb 2, 2013
181
Likes
4,746
#7
i keep threatening to make a mezzanine level in my garage :grin big:
Crank
Aug 16, 2017
107
Likes
169
#8
As I look at the photos again, everything looks pretty bad. After I snapped those, I wiped down the table, carriage and the motor only to find its reasonably nice under that layer of finely aged grinding dust seasoned with just enough oil to be about as nasty as copier toner. I never thought that an import like this would be scraped, but it is and most of it is still present. I'm going to scrub the heck out of the base today and spiff up the cabinet so I can get that all secured. After that, I'll fine clean the other parts before I throw it back together.
If by any crazy chance, someone has a copy of the manual for an Enco specifically, please share. The current Grizzly offering seems enough different, but I'll have to look closer.
Mark
Crank
Aug 16, 2017
107
Likes
169
#9
Well, about 6 hours of scrubbing and I wound up with this.
Mark
Ulma Doctor
Infinitely Curious
Feb 2, 2013
181
Likes
4,746
#10
looks great Crank! :drool:
Crank
Aug 16, 2017
107
Likes
169
#11
I managed to clean everything and put it back together before dark. I need to make a mess and pump a bunch of oil through the oiler to get the ways coated thoroughly. I still need to get a new switch before I power it up again,
Mark
FOMOGO
Sep 2, 2013
1,855
Likes
1,792
#12
That first look had me wondering just how worn it would be, but looks to be in pretty nice shape. After seeing the Tormach cnc grinder in another current post, makes me wonder how hard would it be to retrofit an older manual sg to eliminate all of that wheel turning? Nice score. Mike
Crank
Aug 16, 2017
107
Likes
169
#13
I got a new switch on order, I'll need to get a wheel dresser also. Has anyone bothered to put a DRO on the Z axis for more precion on downfeed? Not sure I have a dire need for precision to .0001, or if it's even possible with spindle deflection on something this light. I'm curious if anyone has thoughts on this.
Mark
P.S. here is a pic back together.
FOMOGO
Sep 2, 2013
1,855
Likes
1,792
#14
Bob Korves
Jul 2, 2014
6,057
Likes
6,387
#15
Just make your own, like this one. I made this one so it would be low profile, so it could remain on the mag chuck while I am working on the part, and so I can sneak over and dress the wheel as needed, which tends to get put off otherwise. I have found that the best way to turn out good work on a surface grinder is to keep the wheel well dressed. Loaded wheels cause many issues, none of them good. The angle of the nib should be around 10-15 degrees, so I make them 12.5 degrees.:rolleyes: The nib should be rotated to a new position regularly to keep the diamond sharp. Very easy project, perfect for anyone new to surface grinding. The sky is the limit, make as many of them as you think you may have a use for, to any designs that suit your fancy, and see how they work out... Store bought ones are no fun, and too expensive for what they are... Here are some other ideas, most of them commercial:
https://www.bing.com/images/search?...-27&sk=&cvid=C7E0A1E576A04852BE5270EDBF485DAD
Bob Korves
Jul 2, 2014
6,057
Likes
6,387
#16
If you put a DRO on a surface grinder, use a 1 micron resolution scale for the up and down direction (and that is Y, not Z on a surface grinder), or even higher resolution if you are going to be doing really fussy work. For the cross feed (Z axis), 5 microns is sufficient. There is little use for a table traverse (X axis) readout.
Crank
Aug 16, 2017
107
Likes
169
#17
Fomogo,
Actually, I saw that machine, but wondered if anyone had a low buck simple upgrade. I haven't had time to surf the interests today. I will dig around tomorrow.
Bob,
Never even thought about homemade. I'll look into it.
Mark
Crank
Aug 16, 2017
107
Likes
169
#18
Bob,
You replied while I was pecking out a reply on my phone. I only would worry about the downfeed. I have seen reference to spindle axis as Z, that's why I identified it as such. My accuracy needs likely will never be aerospace precision, but it never hurts to have.
Thanks
Mark
Bob Korves
Jul 2, 2014
6,057
Likes
6,387
#19
Bob,
Making the dresser is also a good first project for your surface grinder, fairly easy, and immediately useful when finished.
The up/down is the Y, and that is the place where you really can use a good DRO. Z, yes, to a lesser extent. To many machinists, everything is a Bridgeport WRT nomenclature. A horizontal mill has the same nomenclature as the surface grinder, because it is laid out the same. To many CNC folks, they just call it whatever the whim of the day is. Communication is the goal...
Crank
Aug 16, 2017
107
Likes
169
#20
Made a new switch plate and installed the new switch. Looks good and it even works!
Nothing much to do other than getting a diamond dresser and start using it.
Mark
Ulma Doctor
Infinitely Curious
Feb 2, 2013
181
Likes
4,746
#21
looks great Crank! :grin:
shars and all industrial tool supply are good vendors for import Diamond Nibs
C-Bag
Ned Ludd's bro
Feb 9, 2017
540
Likes
370
#22
ANOTHER great score Crank! Congrats. You must be living right. I've had this irrational jones for a SG for a while now and the combo of the price, size and condition would have been impossible to pass up. As my Okie Grandpa woulda said I'm proud fer ya son.
C-Bag
Ned Ludd's bro
Feb 9, 2017
540
Likes
370
#23
So, it's been a while Crank, whatcha think? I ask because a similar one popped up. Same design, different name tag. It's not the bargain you got, and it's not got the single point oiler :( But like you I have limited space.
Have you used yours much? Any tips/regrets? For the kind of $$ you paid it's not likely you have any regrets but I'm trying to get a feel before I leap.
[6]
[5] [7]
