Well I stopped by tractor supply. They had a few with their name on it, but said goldenrod right there on the handle. I get the one with the flex spout fill it with air compressor oil and give it a try. No luck :angry: The tip on the spout is too small for the oil buttons. It will push down the ball, but it is too small to seal around the hole and it all just comes right back out instead of getting pumped into the port.
There are two different size buttons on my lathe, it works on the smaller ones, but not the bigger ones. (there are more bigger ones than smaller ones) So I am kinda back to square one unless I can find a different tip (which does not look like it is removable)
