- Dec 27, 2017
- 340
There are a few smart guys here that can figure out if they can reverse it. I would check with
markba633csi might be able to help
Ok, I'll ask him.
speaking of compressor tanks, I've never had the opportunity to look inside one. Do manufacturers paint them inside for corrosion control? Or treat them in any way?
About 30 years ago u read about a liquid you pour into the tank to prevent rust, then you drain it.speaking of compressor tanks, I've never had the opportunity to look inside one. Do manufacturers paint them inside for corrosion control? Or treat them in any way?
I would think an elastic type polymer should be used in a tank under pressure , expanding and contracting as they most do with temperatures and all. I've never saw a inside painted even on oil tanks for fuel. You'd think they would be galvanised in and out. Just don't understand why not. I've cut up several tanks of different kinds none were painted or coated.
