Well, not a lady per se, but rather my Vectrax lathe. I was installing a set of levelling feet on it and got lazy. Instead of picking it up with my chain hoist like I should have, I had a set of wheels clamped to one end so I could turn it where I wanted it, then I levered the headstock end up using a piece of 2" round stock and a 2x4 so I could slip the studs into the holes, forgetting that it was resting on the wheels. Needless to say, I had my 2x4 in the wrong spot and when I levered it up, it pivoted on the back wheel, causing it to snap, dumping it over.
http://i494.photobucket.com/albums/...15-02/IMG_20150214_134841_976_zpscxemn8b5.jpg
Damage so far is a broken cast iron motor mount, both motor mount pivot bolts, the rear chip guard, the electric box (salvageable), and one busted contactor in the box. I've pretty well straightened out the box and door, and I pieced the motor mount back together using 1/4" plate. I'm going to get pivot bolts tomorrow morning and try to cobble some bushings together because the original bolts are shouldered and I don't have a lathe to build new ones. I'm hoping the contactor isn't too hard to find, it's really going to suck if I have to order it from Taiwan, maybe I'll get lucky and MSC or Enco will have one in stock so I can see what all else is wrong with it.
