- Apr 30, 2015
- 11,900
Perfect except the cost of 3-prong twist lock plugs and receptacles is much more than a switch
After giving this more thought. After its all said and done, you will likely spend over 1/2, if not over the full cost of a second VFD. Consider just buying 2 of the same VFD's. Makes all this mute, and tons easier to wire it all up. Plus, you have a second that can be switched between machines if one goes bad.I never use both at the same time so why bother buying another VFD. What type of switch could I used to switch the 3 wires from the lathe to the mill?
