Doesn't work too well unless you bore the inside of the pipe smooth. Got almost all the way through, then the insert caught on the weld seam (?), broke, and trashed the holder in the process. Luckily the holder was only $28 from Amazon.
This happened all too frequently when I had employees, and is exactly why I haven't bothered to buy an inserted parting tool for my home shop. If you just lost the insert, that wouldn't be so bad. Trashing the blade too is just too high a price. Sharpening a HSS parting tool is something I can teach to my 5 y/o granddaughter, and one blade can last a decade or more for a hobbyist. You can't usually run an inserted tool fast enough to gain anything from the carbide and the sharper edge of HSS makes it less likely that the tool will grab.Doesn't work too well unless you bore the inside of the pipe smooth. Got almost all the way through, then the insert caught on the weld seam (?), broke, and trashed the holder in the process. Luckily the holder was only $28 from Amazon.
Ditto; also black pipe, which is a handy source of steel (-ish) tube.If I need precision on SCH 40 pipe I rough cut it on the bandsaw then face it off on the lathe. HSS works well and won't chip if it hits a hard spot.
I find my Evolution S380CPS dry cut saw is far better than a porta-band, recip or even my Wellsaw bandsaw. It's a lot faster than all of the above and makes a cut that's actually quite square compared to the other methods (not parting of course). Pipe isn't really a challenge....I've cut round solid steel up to 2.5" or maybe 3" with no issues and a lot of 3x1 solid steel as well. The vise has pre-set positions for 30* and 45* and they're repeatable...set it on 45* cut four pieces and you'll have a nice square with very little effort.Porta-band is the best tool for this.
Second is battery powered recip-saw.
Then toss in lathe and FACE the end.
Here is where your chipped tooling or brazed carbide comes in handy as you can use the area along the edge to face the "ribbon" of the pipe.
