- Dec 18, 2019
- 6,539
I want to use something like a PEM nut to tie down a stepper motor controller. Issue is the aluminum Bud box I have isn't that thick. Mic says it is 0.048" thick. Thought I'd put the flange of the insert on the outside of the box and set it with my arbor press. The controller is not that heavy. Using M5 screws. The controller would be inside the box with the M5 screws pulling the controller towards the sheet metal.
Right now, this is what I selected. https://www.mcmaster.com/95185A630/ Are there better choices for this application?
Trying to avoid loose nuts! Too many of them running around the shop as is.
