- Apr 23, 2018
- 6,533
Pontiac428,
My cuts are no more than .025". It takes me over 50 passes to get to a depth of 1.248". Cuts to widen the slot are done in .020" or less, sometimes half that, so it takes 6-12 passes to remove .126" at about 1/2" deep. Then repeating the process 3 times until I get to the desired width and depth. Then repeat that for the other side. No hogging big amounts here. My machine does NOT like big cuts. I'm going to try reducing the .025" to about .015" to see if that helps.
Okay. You should be able to take cuts approaching 0.100" deep and half a cutter diameter wide. How are you managing backlash? On a manual machine, you should only turn the lead screw one direction into your dimension. Avoid overshooting and pulling back, unless you back way out and re-approach from the feed direction again. Whatever the DRO reads is where your spindle centerline is, but if you're in the dead band of your lead screw's backlash, the spindle will wander. On some machines a lot! Not trying to insult; gotta cover the basics first.
