Pin Chuck
Larry Curl
Aug 5, 2015
11
Hi out there, I'm looking for a pin vise that I can use in my die grinder to convert the 1/8 spindle collet to a 1/4 spindle collet - all that I have found convert the other way, from large to small. Also be able to use in my lathe chuck (need straight shank). All help & advice appreciated.
matthewsx
H-M Supporter - Gold Member
Jan 2, 2019
1,705
What type of die grinder are you using? Mine all take 1/4”
matthewsx
Jan 2, 2019
1,705
It’s going to be hard to find something that goes up in size since bigger tools require more power. Have you searched for the tooling you need with a 1/8” shank? Either that or get/build a mount for a larger die grinder that adapts to your tool post.
You might consider a milling spindle with an ER collet built in.
What tools are you trying to use?
Larry Curl
Aug 5, 2015
11
I've been using Dremel grinding wheels, but there is only a limited amount of sizes/grits available. What I was hoping for was a straight shank collet-type holder to use for holding small round stock & to hold small dia work pieces for 2nd operation machining. Example: making a small special machine screw with unique head. Perhaps ER collet system would work, but that gets too pricey for what I need - one-off pieces & used very infrequently.
darkzero
Global Moderator
Staff member
H-M Lifetime Diamond Member
Nov 27, 2012
6,396
A 1/4" electric die grinder will cost $40 from HF. Heck a 1/4" air die grinder is only $10 from HF. Won't be as good a real tool post grinder but they'll give you better results than a pencil die grinder. There's a reason why why they don't make larger size grinding stones for 1/8" shank. You could always turn down the shank of a 1/4" shank stone to 1/8"to try.
matthewsx
Jan 2, 2019
1,705
I've found that if you locate the right industrial hardware store you can get an amazing assortment of tools. When I was porting go-kart heads I used 1/8 shank arbors with different sanding disks and cones, Huntington Beach used to be an aerospace center so maybe they have such a store, check around to see if there's a place that might have suitable tools. Otherwise upsize the grinder for better selection.
Cheers,
John
hman
H-M Platinum Supporter
Feb 17, 2013
2,761
OK, here's a possible solution to your dilemma. I just got a new MicroMark catalog and was paging through it with your need for 1/4" shank tools in mind. Nearly everything they sell goes up to 1/8". But I did see a pin vise with 1/4" capability. It's their part number 21106 ($12.95) https://www.micromark.com/Heavy-Duty-Pin-Vise
If you have access to a lathe, there are two ways you could modify the pin vise to work with your rotary tool.
(1) Cut off the handle and turn down the shank to 1/8"
(2) cut off the handle, then drill & tap into the cut end of the shank to fit over the nose of your rotary tool. Dremel tools have a 9/32"-40 thread on their noses. I've actually done this to some HF 1/2" shank slot cutting router bits that I adapted for use on a Dremel. Bought the taps from VME. Tap drill size is #F.
Tozguy
Feb 15, 2013
2,419
Just a thought but have you checked other sources than Dremel for 1/8th shank mounted stones? The line of Dremel brand ones might be limited but there are other sources (I think). There is also the possibility of using 1/8th shank carbide burrs instead of stones.
To my mind making a 1/8 to 1/4 adapter for your pencil grinder would be a last resort.
AdBlock Detected
I've Disabled AdBlock
