Hey,
OK I think I finally nailed it :
http://www.amazon.fr/CEPSA-640413072-Hydraulique-Minérale-Hydrauliques/dp/B00L073UD6/ref=sr_1_5?ie=UTF8&qid=1411230741&sr=8-5&keywords=hydraulique+68
Can you please give it a look and confirm that would be a suitable replacement for Mobil DTE heavy medium ?
Reads right to me. Oui, cest le bonne huile pour votre machine.
Pierre
For Austin, ISO68 should be fine. Tractor Supply has it -$25 for 2 gallon jug. I would not call ISO68 high viscosity. More like 20w oil. Pretty thin stuff. I put it in the oil can and use it on everything. I would use it on a grizzley 12x36. They called for 20w in my mill, I would use ISO also.
If I read this right (not) its great for separating pollutants, resists deposits, protects corrosion, they are unsure of capacity and provides resistance to mice. My French is rough. ( non-existant). Le Amazon to the rescue. Sounds like the right stuff.
- Grande capacité de séparation de polluants par l’eau (désémulsibilité). Haute résistance à la mousse. Haute capacité anti-usure. Résistance à la formation de boues et de dépôts. Excellente protection contre la corrosion et la rouille.
