[4]
PM-833T MITUTOYO QUILL KIT
[3]
[10] Like what you see?
RIMSPOKE
H-M Supporter - Silver Member
Jan 16, 2016
274
ONE OF THE BEST MODS I DID TO MY PM-833T WAS TO ADD A POSITIVE QUILL STOP .
THE FACTORY ITEM IS TOTALLY INADEQUATE AND MOVES EVERY TIME YOU TAP IT .
WHAT I CAME UP WITH WAS WAY OVERBUILT AND VISUALLY IN THE WAY .
THE NEW VERSION IS GREATLY STREAMLINED .
I MANAGED TO SCORE A MITUTOYO QUILL KIT FOR A BRIDGEPORT AND HAVE
SPENT A YEAR THINKING ABOUT THE BEST WAY TO INSTALL IT ON THE PM MILL .
THESE THINGS ARE IN THE WAY ALL OVER THE PLACE ON A BRIDGEPORT .
SO I WANTED TO KEEP IT MORE ERGONOMIC THAN THE TYPICAL INSTALLATION .
THEY ALSO MOVE WITH THE QUILL ALL THE TIME EVEN WHEN NOT IN USE .
SO HERE IS WHAT I CAM UP WITH .
MY STOP COLLAR IS A TWO PIECE DESIGN & WORKS LIKE A CLAMP ON THE QUILL .
IT IS SECURED BY TWO 1/2-20 BOLTS ON THE BACK & HOLDS THE QUILL STOP ROD QUITE SOLIDLY .
THERE IS A "SHELF" ATTACHED TO THE FRONT OF THE MILL FOR THE INTELLIGENT NUT TO BUMP AGAINST .
ON THE NEW VERSION I ADDED A SLOT FOR THE QUILL READOUT SCALE TO GO THROUGH .
THE READ HEAD IS MOUNTED TO A PLATE THAT IS ATTACHED TO THE FRONT PLATE ON THE MILL .
THIS PLATE COVERS THE ORIGINAL NOW UNUSED QUILL STOP HOLE & SCALE .
NONE OF THIS OBSTRUCTS THE SERIAL # & MANUFACTURE DATE ON THE MILL
I MADE A SMALL BRASS CLAMP FOR THE END OF THE SCALE THAT HOLDS A MAGNET .
THIS MAGNET CAN BE STUCK TO A STEEL BLOCK THAT MOUNTS ON THE MOVING COLLAR
SO THE SCALE RIDES UP AND DOWN WITH THE QUILL .
IT ALSO CAN BE LIFTED AND STUCK TO THE BOTTOM OF THE SHELF WHEN THE QUILL READOUT IS NOT IN USE !
I AM SO HAPPY WITH THE WAY THIS TURNED OUT THAT I WANTED TO SHARE .
Tekwip
Newbie
Apr 2, 2017
3
I have been wondering about how to approach this on my PM 833T. Thanks for the ideas.
[6]
[5] [7]
