I was looking for a new project and saw the number 7 engine on the PM Engineering site. I looked at it and it had 1/2" cylinders. That would allow me to work with my existing tool inventory. Little did I know that I was jumping into the deep end of the pool. There were 25+ tiny parts to make. In most cases times two because there are two motors. It was my first work with a casting and all of the required clean ups needed for a casting. Each of the cylinders have 13 holes and ports.
After may hours (I stopped counting at 20) it is complete and runs great. I chose to leave the connection between the two motors as a soft tube. Once it is replaced by a hard tube the disassembly will be almost impossible. Maybe after I convince myself that there will be no need for repair or update I will take that step.
I have timed it as good as I can. Most of the techniques out in the forums and YouTube don't work on something this small.
I am more of an engine builder that a model maker. That is why some of the details like oilers are missing. They are mostly for show and not needed for the low time that it will be running.
