- Nov 27, 2012
- 7,865
I was going to say for the carriage lamp but IIRC mine only has 2 wires & not that 3rd common ground wire (assuming the wiring color is hooked up correctly). If that grn/ylw wire is labeled PE in the control panel it's common ground. Check the voltage on the brown & black wires. Lamp is 24v, I forget the pump is 24v also but that's easy to determine, should shutoff with the coolant switch.
The hole on the chip pan is for the coolant nozzle, I just put a cap on mine for now.
