U
umahunter
Forum Guest
Register Today
Ok I have to remove the quill from my mill to replace the bad spindle. I removed the return spring and thought I could pull the handle out like on a drill press but that isn't working. do I need to remove these 2 screws in the pic B and remove the whole assembly in order to get the quill out also do I need to remove the 3 screws and plate in pic a it doesn't look I need to just don't wanna pull the wrong part and make more work thanks for any help
