- Oct 10, 2018
- 543
And the tool being used, please!Would love to see some follow-up photos of stone work using them.
Craig
Craig
Just beautiful.Well it’s been a while, but as promised here’s a few shots of the irons being used and what they produce.
The joints have been raked of all old mortar and the new lime mortar is packed in using standard trowels. The object is to fill the joint fully and evenly, but not necessarily worry about being pretty at this stage. Once the filled joints have set in for a little, the pointing iron is brought into play to create the bead profile. In one or two passes, the smooth bead is created in the soft mortar. These irons work exceptionally well, and the joint is straight, crisp, and very smooth with no pulling or dragging.
After the beads are formed, excess mortar on either side is flicked off and the joint is further refined.
And finally the finished joint at close to full cure. Remaining sand on the surface as well as any leftover staining around the edges will rinse off later leaving a clean, crisp, and fully-formed raised pointing bead. It’s still close to freezing at nighttime here and with traditional lime mortar that’s not good, hence the packing blankets while the mortar cures.
So there you go, thanks for looking (again)!
-frank
-frank
