- Apr 6, 2011
- 2,082
Likely #8-36, which is UNF. Not super-special, but not going to find it at Lowe's. Drill a hole in a piece of stock to fit over it, and give it a tap or two. I still like the heat.
Thanks Tony. I don't have any taps or dies that are 36 tpi let alone a #8 but that should give me something to work with. Application of heat may still be in the cards but it doesn't look like it will do it on it's own. Third times a charm?
Not to sound too obvious, but have you tried Kroil?
Of all the stuff I tried over the years this one is close to miraculous.
I'll have to admit, as much as I swear by Kroil, it didn't really cross my mind. The area I'm dealing with is so small and there is no "corrosion" (okay, okay, "bluing" is technically rust but....) to speak of so I figure I'm dealing with metal on metal. I'm not sure if a penetrant would do a lot of good in this case. Interesting suggestion though. I will definitely mull it over.
Thanks,
-Ron
