- Mar 22, 2013
- 498
We came up with a fix for this a while back, if anyone has this problem please contact us directly if you are the original owner of the machine, we had that hole moved to a different spot and larger T nuts made.
Doesnt everyone who purchased a lathe, 1340GT & 1440GT, with this particular cross slide design have the problem?We came up with a fix for this a while back, if anyone has this problem please contact us directly if you are the original owner of the machine, we had that hole moved to a different spot and larger T nuts made.
Jay: I checked -- after reading your earlier post -- and I do have the problem on my 1440GT. BillDoesnt everyone who purchased a lathe, 1340GT & 1440GT, with this particular cross slide design have the problem?
Sent from my SM-G955U using Tapatalk
This was a major reason why I went to a solid riser under the tool post.Jay: I checked -- after reading your earlier post -- and I do have the problem on my 1440GT. Bill
The Grizzly G4002 is similar. I made a minimally larger t bolt, which solved the problem so far.
