Thanks for that.
Best I can tell the green HF belt is an AX which is 1/2” vs the 5/8” of the BX. So, maybe either works.
The green belt absolutely works for me. But then I don't 'hog' metal on my 1340, and have only run in reverse a few times. YMMV.
You're running an A belt on B pulleys? Interesting, never thought it would grip properly but if it works....
My lathe uses dual 1/2 width belts so I'm running A belts. I run in reverse all the time to machine tapers. I never need to hog material in reverse. The Power Twist belts are just a tad bit noisier in reverse but I've never had a problem yet. Been running the same belts for almost 10 yrs now.
