- May 7, 2023
- 1,467
I also have a separate New question. I edited the thread to include it starting at this post.
my old Bandsaw wheel pulley is worn.
The reason for addressing this issue is I want to avoid vibration and ticking as much as possible. I am not certain if extra steps are needed to repair the pulley. The pulley is unobtainable from online supply.
The amount of wear is small.
- This is a 5 mm nominal keyway. The key was measured to be 0.1964" in both directions and front to back. So I concluded that the key is not damaged. as the pulley is made of aluminum.
- it does not wiggle on the shaft, but does wiggle in the pulley.
- when everything is installed on the shaft, I feel ticking when going back and forth.
- there is no setscrew.
- Ithe pulley keyway cannot be measured accurately as it is too small for my new telescoping gauge set. visually I can see that it is very small.
My potential solution is
the question is should I apply the Loctite 608 to the sides of the pulley keyway since there is wiggle in pulley and no setscrew
- Loctite 608 on the sides of the keyway only. I spoke to the Henkel rep. He said that Loctite 608 can be used in this application but could not comment on the efficacy.
- do nothing
- buy new pulley locally made for over $100
thanks
View attachment 451835View attachment 451836
That might work, but I would mill and hand fit a stepped key and call it done.
