- Feb 26, 2014
- 258
I have a Tripan 211 model and can confirm mine does hold .001" or less.
No in a nutshell .Lets say I am turning down multiple parts to .250". When I switch to a cutoff tool and cutoff then replace it with a turning tool, will it cut exactly .250" at the same dial position?
Are you saying that you use the dial indicator to check position after each tool change? Import tool post? wedge or piston?I make a lot of small parts where I swap the cut off tool, RH tool & diamond over and over again. I use the dial indicator for position on cross slide and get about .001 repeatability. I set the compound at 6 degrees and measure the part and use the compound to get within a couple of tenths.
I have a self made quick change toolpost. I have measured the repeatabilty on the small lathe. I get (3S) 0.02 mm in turning diameter (outer turning). That means that in 99% of the tool changes, the turned diameter is withing 0.02 mm, a bit less than 0.001".If you are looking for a tight tolerance go to an Aloris or Dorian. Quality and accuracy is expensive. Remember the old saying from the hot Rod days. Speed costs. How fast do you want to go?
How can a locked 4 way post be quick change? Photos?I have a self made quick change toolpost. I have measured the repeatabilty on the small lathe. I get (3S) 0.02 mm in turning diameter (outer turning). That means that in 99% of the tool changes, the turned diameter is withing 0.02 mm, a bit less than 0.001".
To achieve that, the 4 way tool post is locked. It can't be rotated any more. All tools are shimmed at the bottom to set the tool heigt, at the back to position them under the bolts and on the top so I only have to losen the 2 locking bolt half a turn. At the back of the tool there is a small stop to position (stickout) the tool always the same way. After a few months I replaced the the 2 bolts by a single handle locking system.
Dorian makes an Aloris - type tool post with 4 holding positions, so it is both 4-way *and* quick change.How can a locked 4 way post be quick change? Photos?
