There may be much better ways to accomplish this but, I wondering if it can be done with the QCTP and holders I already have.
I'm turning both the inside and outside of a cylinder. For the inside I install a boring bar on the QCTP, for the outside I install an indexable cutter on the QCTP. This requires swapping cutters and making two passes, one for the inside, one for the outside. If both cutters were installed at the same time that would lead to one pass and done.
The QCTP and it's holders don't allow for two holders to be installed at the same time. I wondered to myself, what if I cut off the end of a holder so they can both fit on the QCTP? I don't mind ruining a holder to see if this will actually work but, they are made of hardened steel, I have no way to cut that. I haven't tried grinding on it, that may be a possibility.
Maybe "skinny" holders are available, I just can't find one.
Ideas welcomed, thanks.
