- Jun 12, 2014
- 4,828
At one point I tried using a ER40 block in my 4 Jaw chuck and the TIR/skew was a problem as well as being awkward. I see no reason to have a 5C to ER40 adapter, you are limited by the diameter of the 5C, you have more stick out from the chuck and more compounded TIR from stacking. By the time you are all said an done you would be better off just getting a direct mount ER40 chuck and a 5C chuck. I have both, I made my own ER40 set-true chuck, I only use it for odd diameter work and prefer the 5C. Technically an ER chuck system has more holding power if the stock extends the full length of the collet, but I have never had an issue with holding power of my 5C.
The other advantage I see for using a dedicated 5C or ER40 chuck is you can use your hands very close to the chuck without fear that a jaw is going to rip off a part of your finger. The main reason for my initially posting the information on these set-true style collet chucks was that they were nicely made, accurate and reasonably priced. I know a couple of people that purchased the QMT 5C set-true chucks and have been very satisfied with them.
Mark
Mark
