[4]
Question on Bearing cup pocket size?
[3]
[10] Like what you see?
Mike8623
Active Member
Dec 18, 2013
127
Likes
27
#1
OK guys I've got a project where I have to mill a hole for a race (bearing cup) and insert a bearing. My question is how much undersize should you mill the pocket to press in the race (cup)
Ray C
Platinum
Staff member
Nov 16, 2012
5,215
Likes
1,443
#2
Without knowing exactly what bearing you have it's hard to give an exact answer. Generally speaking, you do not want a very tight fit at all. I'm assuming a taper bearing of around 1-2 inches or so. Maybe 0.0002 to 0.0004". Anything tighter than that and you risk damaging it or warping it out of shape.
Ray
Mike8623
Active Member
Dec 18, 2013
127
Likes
27
#3
It is just a little under 2" so I'll for .0002"
Thanks
mikey
Dec 20, 2012
4,650
Likes
5,039
#5
Whenever I need to bore a hole to fit a bearing I contact the bearing manufacturer by email and ask them for clearances. There are so many different bearings and the fit has a direct impact on internal bearing clearances. The maker will know what you need. Being able to bore to that dimension, which will usually be in the micron range ... is another thing.
kd4gij
Feb 7, 2011
4,674
Likes
1,848
#6
What material are you using?
C
cg285
Guest - Please Register!
#7
Mike8623
Active Member
Dec 18, 2013
127
Likes
27
#8
I'll be placing the bearings (2) in aluminum. I'm actually making a rifling machine for my lathe and am using two wheel bearing for a shaft on which a pinion gear lives and interacts with a gear rack.
BtoVin83
Active Member
Aug 30, 2017
190
Likes
182
#9
If using tapered roller bearings you can utilize a fair amount of press fit as the bearing clearance is made up between the bearings, ball bearings the clearances are built in and cannot stand much press. Tapered rollers don't like out of round.
Mike8623
Active Member
Dec 18, 2013
127
Likes
27
#10
I want to thank all that replied. I got just the type of answers I was looking for from the forum, thanks again.
I was born and raised in Bakersfield, but moved to Montana a long time ago.
BtoVin83
Active Member
Aug 30, 2017
190
Likes
182
#11
If you haven't been back to Bako in a while you might not recognize it.
BtoVin83
Active Member
Aug 30, 2017
190
Likes
182
#12
One more thing, with aluminum housings we put a tad more press on the bearings compared to steel as the aluminum can heat faster and expand faster and sometimes the brg can start spinning. Nice thing about tapered brgs they can stand the press and not self destruct.
C
cg285
#13
i always understood it was the grade of tapered bearing that allowed more or less press fit. c3 comes to mind as one with looser tolerances that has a greater press acceptance
[6]
[5] [7]
