I have a one off project for which I may use a 10" rotary table, oriented vertically, with a 6" lathe chuck mounted on it, on my mill table. I would need a tail stock to hold the "far end" of the work.
I don't own an appropriate tail stock, and I typically like to think about fabricating specialty tools before I buy them. So far I've thought of employing:
1. Simple angle iron drilled at the appropriate height to hold a straight shank center of some sort.
2. An angle plate deployed similarly as above.
3. Adapting an old, heavy duty wood lathe tail stock I already own, with a spacer plate to obtain correct height.
4. Employing a spin indexer with a similar spacer plate as above
So far I'm leaning toward #3. Anyone done such a thing?
