After putting new solvent in, cleaning oily parts at what point is it going to be a problem with paint again?It won't hurt the solvent much, but if you ever want to paint anything you wash without washing it twice to get the ATF off, leave it out of the tank.
The direct answer about ATF preventing evaporation is no, it won't make a difference, but as someone who every once in a while has to calculate the fugacity of chemical components in mixtures using Henry's law or Raoult's law, there is indeed a difference, but it's negligible for us in this context.
I like geeking out over chemicals.
The heated ozzy juice system works great. The bio mat filter is another plus. Its a added maintenance so that has to be accounted for.I use a heated parts cleaner tank with a bio-degreaser I beleive it’s called ozzy juice. The system works great being heated. I’ve purchased the ozzy juice refills at oreillys.
we had to stop using simple green to clean aircraft parts. Left a residue that eventually would build up enough to jam close tolerance parts.The heated ozzy juice system works great. The bio mat filter is another plus. Its a added maintenance so that has to be accounted for.
Steam cleaner even a small cheap one is great to have on hand.
Simple green works well as do many orthers some dont play well with aluminum.
Yes I have used xylene base paints before. Still do, from time to time. You still have to clean the surface *very* well. If you don't the cure time takes a big hit - from 20 minutes to 2-3 hours if there is oil residue on the part. We buy and use the Xylene primer because we can recoat with finish paint almost right after priming. It is also much harder, which is very desirable in some applications.there are paints which can still adhere to a surface that has a slight contamination to lighter petroleum products
Nice to know. I was considering making a vat of simple green. I wonder how Purple Power compares?we had to stop using simple green to clean aircraft parts.
