.... ok ... here is a very *very* minor gripe, but if your petroleum solvent is high enough in sulfur compounds to stink (badly), it will also eat zinc. That keeps 7050, brass AND bronze out of your tank - well, because it leaches the *copper* out of the alloy almost as well as the zinc.
Now if all you do is dunk, brush, and blow off, no probs at all. if you *soak* like I do, then you have to go to 0% sulfur low odor varsol to stay away from the sulfur. (the stinky varsol has other components that seem unfriendly to 7075 aluminum, but I haven't investigated)
I now have a citiric acid bath for primary derusting, an evaporust tank for secondary derusing, and a low odor varsol bath for cleaning. I use acetone to clean off parts from the varsol tank before bead blasting and painting.
