- Sep 25, 2014
- 1,116
This is one of the centers that came with the lathe -- it is specifically meant for the tail-stock ram (the spindle is a different size).
It just has wear and needs to be re-pointed. There was a comment earlier about it not being worth fixing -- I'm pretty sure these are meant to wear and be cleaned up periodically; it is a dead center after all and will be subject to a lot of friction. I would rather have the $5 tool wear than the part I'm trying to turn... Decided to lookup the part on grizzly's site to check whether it was supposed to be hardened or not, and couldn't find it as a replacement part. Did find that most listed are hardened - but I'm still pretty sure the ones that came with the lathe weren't...
My live center is pretty fricking huge, which makes it just about impossible to get a tool anywhere near the tail end of the work piece (even coming at it with a right-handed cutter) without a large cutter stickout... I should probably look for a smaller live center as well now that I'm thinking about it...
The size does not determine the location the center would be used. Usually the lathe manufacturer provides a sleeve for the spindle taper, and the reason is so you can both have a good sized spindle hole and employ reasonably sized spindle tooling for the machine (i.e. you probably don't use much MT4 tooling on a G0602). A 4MT center is pretty big, it may take up additional bed length.
You are correct about simply re-pointing. It is true that new ones are cheap, but repointing is very straight forward.
You raise a good "point" about not wanting to wear the part. When a center wears, it will wear the part. So long as the wear during the job is minor, you can finish that job - then fix the center if need be. If the center wears during the job - well, that is not so good. Obviously you can do things to minimize this wear: lubrication (which you have already "pointed" out), don't let the load get too high (manage thermal growth, keep the tool load down), don't run the speed too high and use a hard center. Most folks likely use soft centers in the tailstock from time to time (if I needed to get in close on a small part, I'd grind out some room and get'er done - then repoint the center).
Griz doesn't have this as a replacement part, yet they supplied it with the lathe (perhaps their price on soft centers is $0.02 cheaper, which helps them keep costs down)? Griz sells lots of stuff, but there is plenty of cool stuff that they don't offer (others do). Most centers sold probably are hardened since tailstock use is likely the more common application and more likely to get damaged. A head stock center should last a long time, and is very easy to repair.
Did you get two centers with your lathe? Was one of them hardened?
If you do much small work in close to the tail stock, consider getting a half center. You can get extended point live centers, which help on getting in close to the tailstock, but that does eat up some bed space. I think you are on the right track to sort out using dead centers. Live centers are great, but folks should not reject using dead centers - they bring a number of benefits (stiff, cheap, short, simple, easy to service, can be very accurate).
