Slicing off the screw is a gamble. If the cut off wheel slips or hits the chuck, it will get marred.
The screw is too close to the body.
Q: If I use a left hand reverse drill, do I run the Bridgeport mill spindle in reverse? Spinning counter clockwise?
Do I use oil? For a small drill bit, 5/64" - 1/8" what would be a good speed to run them in, RPM? If it doesn't screw out, I will have to drill through. The collar is most likely "munged", jamming the wrong screw in the collar probably ruined the threads. Buying a new collar will be less expensive than buying more drills, ez outs, taps,screws, etc...
Plus all the extra time, of which I don't have a lot of extra.
Also, there is a 1/2" straight shank arbor, JT2 in this 13mm Albrecht chuck. It doesn't have enough shoulder to use the #2 Jacobs wedges, so I will have to somehow remove that too!
Thank you all.
Thanks Mikey, you're very knowledgeable about all things Albrecht.
