Yea, those are solid, I replaced them when I built the beefier 4 point ring for it. There is no movement there, there is a few thous of rocking between the actual slide lower half and the upper half (the sliding half.
12bolts,
I initially described it a little wrong by saying the gib set screws where on the bottom half. I have attached a pic for clarity. Note, this is not my lathe or pic, I have just used it for the purpose of drawing on since it would be quicker than taking new photos. The circle is just to note where the movement is and the line drawn is to simulate where the gap appears when rocked (between the two halves). It isn't much, just a few thous, but that is enough to effect the finish.
ScrapMetal,
After I shimmed out the lathe again and ensured it was level I just tested it, and it still creates a taper. I've ran my dial indicator (anchored to the cross-slide) down a straight bar that has been centered using a 4 jaw chuck and centered at both the chuck end and holds center at the unsupported end while manually turning (left off tail stock just to see for sure) and it test dial holds 0 while moving the carriage up and down the stock which should mean the tool should run even up and down the stock and cut even. However, it still gives me a taper on this longer stock. I normally turn small parts on this thing and now that I'm using a longer piece of stock that requires some precision I'm just noticing it and I'm baffled how the taper could be introduced. I'm going to test again with the lathe running and make sure centripetal force isn't throwing the end out a bit causing the taper but I suspect it will be true because it is being supported.
Sorry, this sounds like I'm trying to throw a bunch of issues into a single thread, but I swear this isn't my first rodeo but I've only recently started using this 9x19 lathe for more stuff now and trying to clean it up.
