- Mar 21, 2018
- 1,612
I'll also try the other a gray scotchbrite pad as mentioned above.
The scotchbright will scratch the paint AND the metal - it contains an abrasive, so do NOT use it. Go solvent only.
Be careful using naphtha as a solvent, very similar to gas (petrol) It is also more toxic than gas if you breathe it, and very bad for skin contact.If you're not comforable with using straight gasoline, you might try diesel - or even naptha.
If you want to avoid the hazards, and solvents altogether, and happen to have one of these low-cost steam cleaners intended for kitchen floors, bathrooms, and much else, I can attest that they do work. The heat melts and cuts through wax, and all.
