Came out nice. I was just curious - did your lathe come with a set of change gears?
Yes it had all the accessories with it.
Ok im confused so I have another Rookie question (yeah I know, AGAIN!) Aren't change gears something you need for a lathe Without a qcgb? Doesn't the lathe in the picture have a quick change gearbox on it?Came out nice. I was just curious - did your lathe come with a set of change gears?
Just take the wheels off and ad a set of leveling feet and you should be good to go. Worse case if its still not short enough then I would either cut the extra length off or add an inch or 2 of some fatigue rubber mats in front on the lathe to stand on. I would use the money you would spend on the stock bench for some other useful toy I don't have but would like to!The previous owner made the stand 10" taller than a stock stand. I did some turning on it today and I think it is a little taller than I'd like (i am 6ft tall). I could take the wheels off and that would drop it 4 or 5". I'll keep an eye for the stock stand to go on sale and maybe ditch this one.
