[4]
Restoring a pre-ww2 southbend lathe
[3]
[10] Like what you see?
Bansheedave
Newbie
Feb 15, 2018
18
I picked up a 1936 sounthbend 13” lathe from a garage sale recently. It is missing a few parts. Who would be a good source to get parts from? My lathe came from a school and is a basic machine. It does not have a quick change gear originally but it came with one. I believe the previous owner was converting it. Will it be possible to change and what drive screw would i need? Thank you for any help. I added a picture of my lathe.
ThunderDog
Active Member
Dec 12, 2014
250
Hi and welcome. I'm sure others will be along to provide more insight. Are there more items that came with it that are not in the picture?
I would start the never ending always rechecking and scouring of CL and ebay. I lean on CL more often due to convenience and prices are usually more within the scope of reason to my budget. Regardless, if this is your first lathe let the fun begin!!!
Bansheedave
Newbie
Feb 15, 2018
18
It came with a 4 jaw chuck but I’m missing the correct backing plate to mount it. Came with a lot of tooling and a bunch of gears. That’s pretty much it. I ordered a tail stock off eBay and a few parts to go with it. As far as getting the quick change mounted up, that’s the easy part. The lead screw I’m not sure about or know what i need and that’s if i can even use it on my lathe. I’ll also be pulling the 3 phase motor out and dropping in a single phase replacement. And that leads me to another issue. I am missing the flat belt drive pulley from the motor. I’m not even sure what it looks like or it’s size. I can’t order the belts until i get it.
Bansheedave
Newbie
Feb 15, 2018
18
And thank you for welcoming me. I’ve worked in various machine shops over the years but this is all new to me. Interesting for sure and can’t wait to get it up and running.
markba633csi
Gold
Apr 30, 2015
3,457
I believe it's actually a v-belt pulley and belt from the motor to the larger flat pulley. Sounds strange I know but it was commonly equipped that way from the factory-it works
Mark
ThunderDog
Active Member
Dec 12, 2014
250
Some food for thought, I just purchased and installed a VFD for the first time so that I could run my 3 phase motor on the lathe. It was super easy and I'm no electrician for sure.:eek 2:
pineyfolks
Apr 30, 2012
1,078
Check out the Facebook group south bend lathe buy sell trade. There's a lot of parts on it. That should make a nice machine when finished.
Bansheedave
Newbie
Feb 15, 2018
18
I would buy a vfd but the motor wiring was chopped off. I don’t think it would be worth fixing it.
dtsh
H-M Platinum Supporter ($50)
Sep 22, 2017
135
Hello and welcome!
As another owner of an older lathe, I can appreciate the effort. For the belt, I would suggest trying to get a serpentine belt. When the flat leather belt on mine broke back in the falls, I fitted a serpentine and it behaves like a much different machine now.
Best of luck!
Bansheedave
Newbie
Feb 15, 2018
18
Hello and welcome!
Best of luck!
I need to find a drive pulley first. I’m not sure how hard that’s going to be. Thanks for the support
brino
Jan 2, 2014
3,541
Hi @Bansheedave ,
Welcome to the group!
You got yourself a project right there.
If you have not found it yet we have a "Southbend Downloads" section here:
https://www.hobby-machinist.com/resources/categories/south-bend.34/
with nearly 500 documents it in.
There are many manuals and brochures that could show you what the original parts looked like, and maybe even some part numbers that could be cast into the replacement parts.
If you do not find anything there suitable for your lathe, post back with the "Catalog Number" and I'll see if I have anything at home.
-brino
Bansheedave
Newbie
Feb 15, 2018
18
Hi @Bansheedave ,
-brino
Thank you very much. I did not know about it yet. I’m at work and haven’t had much time to go threw the forum.
Tim9
Oct 11, 2015
205
"I believe it's actually a v-belt pulley and belt from the motor to the larger flat pulley. Sounds strange I know but it was commonly equipped that way from the factory-it works"
Mark
I think Mark is correct. Its an odd set up but on the 9" South Bend it is definitely a V-Belt on the motor which drives the flat pulley on the countershaft. Pick up a copy of...How to run a lathe" which was written by South Bend. You'll find so many answers in the little book. Used copies are always available on Ebay. I have one which came with Atlas Lathes and one from South Bend. They are both basically the same however I find the Atlas is a little more descriptive for things like grinding tooling while the South Bend is geared more to the working of the lathe itself.
Bansheedave
Newbie
Feb 15, 2018
18
Mark
I’ll go look at the lathe tomorrow to be sure but i don’t remember seeing a v groove pulley attached to the countershft. Just a very large flat drive pulley that looks to take a 3/4 in wide flat belt. I’ll look again tomorrow like i said and post what i find.
markba633csi
Gold
Apr 30, 2015
3,457
You could attach new leads to the motor and then buy a VFD to run it. Not too difficult and you'd have variable speed (nice to have)
You'd have to open up the motor to do the soldering repairs so a little bit of work there, and you'd probably want to replace the bearings too, so it's your decision..rebuild or replace
Mark
brino
Jan 2, 2014
3,541
Here's a free one: https://www.hobby-machinist.com/resources/sb-how-to-run-a-lathe-1966-27th-edition-56-pdf.2909/
-brino
EDIT: ...and here's the Atlas Manual of Lathe Operation (MOLO):
https://www.hobby-machinist.com/resources/atlas-manual-of-lathe-operation-molo-and-machinists-tables-23rd-edition-1967.3264/
Bansheedave
Newbie
Feb 15, 2018
18
Well, i looked at my drive pulley and it is a flat belt drive only, no v belt. Going to be hard finding a few parts that I’ll need to make it operational again. Ordered a few parts like the tail stock and wrench and the gear change cover support as the original one was broken. But that’s about it.
Is there a company that sells a backing plate for a 4 jaw chuck(not sure of the size off hand) that will thread on to my head stock? The threads are 1 7/8 x 8 tpi.
Tim9
Oct 11, 2015
205
Looks like the pulley at the motor is grooved. If so....or maybe in any case...I'd lean towards going back with serpentine belts. They work great on these old flat belted machines.
Bansheedave
Newbie
Feb 15, 2018
18
No pulley on the motor. That’s a missing link.
Tim9
Oct 11, 2015
205
What is that a picture of in post #7. The first picture with the ruler. I thought that was your motor.
Edited--- My bad. I was looking at your spindle in post #7.
Bansheedave
Newbie
Feb 15, 2018
18
That’s where my 4 jaw chuck is supposed to be. I need a backing plate to screw on to that and bolt to my chuck.
Silverbullet
Gold
May 4, 2015
3,448
I'd bet you would use the original lead screw, it's getting the gearbox mounted and connected. You'll need the gears for the banjo to match up . If I were you I'd get two pulleys double belt vee in the 3" and 6" . Replace the motor drive , the lower large flat to the head can be a good system been working for a hundred years or so. I'd find a better way to oil the setup on the bottom. A reservoir with lines to the oil holes down under couple of wicks to regulate the flow. I see odd things in pictures these stood out.
local1
Jan 27, 2018
5
I have a 47 Bridgeport that i would like to paint the color of your lathe. Would you happen too know where what the code # is
or even a close match? Im thinking brush on since its still cold here?
Bansheedave
Newbie
Feb 15, 2018
18
I do not know the color code, sorry. It was painted green when i purchesed it. It was originally grey in color. The lathe used to be owned by a local school. They probably are the ones who painted it green. I believe it is an oil base paint the way it is flaking off. I’m hoping it doesn’t contain lead. To answer your application question, I’m sure you can brush it on and have it flow out so no brush marks are in it. Me, I’m probably going to spray it out of my cheap pot gun.
agfrvf
Active Member
Mar 13, 2017
160
Southbend lathe just got brought back to life. You could try them for parts.
[6]
[5] [7]
