[4]
Rf 30 spline wrench
[3]
[10] Like what you see?
Sylvainmom
Newbie
Dec 4, 2017
19
I know there were many posts about this topic but, in order to give another option, here’s what I’ve done this morning. This is made out of a simple hexagonal 1-3/4 ‘’ bar and I use an adjustable wrench to hold this device.
woodchucker
Bronze
Nov 25, 2015
1,504
At first when I saw it, b4 I read your post, I thought you took a hex die, and ground it down inside. Good solution.
Sylvainmom
Newbie
Dec 4, 2017
19
The hexagonal shape was basically used for indexing. As this is a 6 splines shaft, you dont have to bother with a dividing head. It doesn’t always have to be complicated!
C-Bag
Ned Ludd's bro
Feb 9, 2017
595
What I like is it's nice and thick. I bought one of those homemade ones off eBay an it was maybe 1/8" thick and when I used it I think it left dings on the splines. I'd never felt the head hang up before during down feed, so I tossed it. Yours there is no way it's going ding the splines. Good job.
Cobra
Apr 24, 2013
652
Any reason that I should not be just putting the mill in L-1 to tighten and loosen the collet drawbar?
kvt
Oct 21, 2014
2,037
Good Idea, I may have to try that. I just got an Enco 30 that did not have a spline wrench. Now I have a project for it.
Sylvainmom
Newbie
Dec 4, 2017
19
Most of the time, you wont have to use this tool since the draw bar is quite easy to unscrew but, since this is not a gear head machine, no matter the speed you've chosen the spindle will turn easily.
Cobra
Apr 24, 2013
652
Very correct. With the gears in the lowest setting, the spindle is difficult to turn.
Sylvainmom
Newbie
Dec 4, 2017
19
With my belt driven rf 30, no matter the setting, the spindle turns easily
[6]
[5] [7]
