[4]
RF30 or RF31
[3]
[10] Like what you see?
Investigator
Active Member
Jun 8, 2016
264
Just curious, I have seen reference to both model numbers but cant figure out if there is any difference. I realize they are somewhat generic numbers since that machine design is imported by so many dealers. Can anyone tell me the difference or specifics of both?
R
Robert LaLonde
Guest - Please Register!
RF30 is discontinued?
mikey
Dec 20, 2012
5,109
I honestly don't know the difference. Both have the same specs so for all practical purposes, they're the same. We know at least the bearings are the same, right?
C-Bag
Ned Ludd's bro
Feb 9, 2017
676
Yup, so far all the other parts like X &Y split nuts are the same. I'm convinced the difference was cosmetic. I've also seen different Z stops for the different models. I guess it's just where they were made (Taiwan or China) and who they were made for.
Investigator
Active Member
Jun 8, 2016
264
I wonder if at one point one model was an upgrade, like maybe it had power down feed or something like that. Be curious to see some older models to compare. I could see the factory doing away with the less popular model, and having only one model with options. Right now, Rong Fu only has the RF31, with the RF31NSF having power down feed.
clif
Sep 8, 2014
36
Here are the two manuals for the two machines,
RF-30 http://www.hobby-machinist.com/attachments/rf-30-pdf.128232/
RF-31 joebullisproshop.com/Pro Shop/Complex Machine Instruction Manual.pdf
Notice the part numbers for the two machines are different.
I own a RF-30 made in 1983 imported by Enco, have the original manual for it too.
darkzero
Global Moderator
Staff member
Nov 27, 2012
3,434
Yes, but only discontinued by Rong Fu. Others still make RF-30 style machines but as far as I know RF-30 & RF-31 are basically the same, at least I could never find any definitive differences.
When I was searching for a mill, I always wondered what Rong Fu's numbers meant. I used to think it was the size of the table but that didn't seem to be true. Rong Fu lists their RF-31 table to be just under 29". And others who make these style mill drills may offer different table sizes. A RF-45 doesn't have a 45" table either.
So what do Rong Fu numbers mean? They use the metric system right? Well mostly, many Rong Fu & other Taiwan made machines use SAE fastners. Closest thing that I found that made sense is their recommended max drilling capacity. But that's still off, closer but not spot on. RF-31 is listed to have 32mm drilling capacity, RF-45 is 40mm.
I guess we'll never know. :cower:
mikey
Dec 20, 2012
5,109
clif
Sep 8, 2014
36
don't know just posted the manuals for reference
ndnchf
Active Member
Oct 31, 2016
202
If it is any help, here is my Enco/RF30 I bought new 16 - 17 years ago.Enco RF30.jpg
mikey
Dec 20, 2012
5,109
Yup, looks identical to an RF-31. I'm thinking that the RF-30 was an earlier model designation for the same mill. We at least know that the spindle and drive sleeve bearings are the same. It follows that the spindle and quill are also the same. Enco/MSC has or used to have parts in stock. You need the parts manual for your mill in order to give them the correct part number. For what its worth, the spindle itself is not hardened (much) so it may be a good idea to order a spare spindle if you plan to keep your mill.
C-Bag
Ned Ludd's bro
Feb 9, 2017
676
I agree Mike. For all its supposed shortcomings the G0760/RF31/30 continues to be sold to people just like me. Who don't have the room or floor or $$$ for a knee mill. And don't want a mini mill. Knowing its shortcomings but knowing there are a ton of them still working and there are folks doing good work on them made me jump on mine for $400. Yeah, it was rode hard and put up wet, but you can still get parts and there is a huge fan base out there with some cool mod's. It is elusive on the particulars but I'll be willing to bet the change from 30 to 31 was your typical "new and improved" and could have been as simple as them going to all metric hardware or something like that. Mine is also an Enco and very similar to ND's.
clif
Sep 8, 2014
36
One thing I noticed is the RF-30 has lower speeds listed than theRF-31;
IE slowest speed for RF-30 is 120 rpm, where the RF-30 is 150 rpm, upper limit is 2500 for RF-30, 3000 for RF-31
Btw i thought about all metric hardware, but reading the RF-31 list of parts, it is a mix of metric and inch bolts listed.
mine is older Enco RF-30, looks very similar to this one;
but has the Enco tag
C-Bag
Ned Ludd's bro
Feb 9, 2017
676
Not trying to be a jerk here. By the look of the column it's not a RF30. Looks more like 20 or 25.
clif
Sep 8, 2014
36
The pic is RF-15 actually, but mine is a RF-30. I just posted the pic because the look and some details of the early to mid 80's RF-30 are different then the later RF-30's
The manual that came with my machine covers the RF-30, 20 and 15
C-Bag
Ned Ludd's bro
Feb 9, 2017
676
My RF30 was made in '88 and looks almost exactly like ND's except for the switch. I am in no way an expert on the RF line but have seen a ton of the different models on CL (vast majority the RF30) and this is the first time I've ever seen the N2F power down feed or noticed it in the manual. Learn something new everyday.
[6]
[5] [7]
