- Mar 18, 2011
- 243
I took my Rohm apart and it was similar to a Albrecht. It was straightforward to disassemble, reassemble, and now works fine. The biggest problem with keyless chucks is too much oil/grease in them. You might try washing it out with solvent assembled, then make sure the bearings are very lightly lubed and probably nothing else. There will be enough in there to lubricate them. The shell to the jaws should be a dry fit, no or extremely little lubrication. I put oil on those parts, wipe them off completely with a clean and dry rag, and then assemble. Inertia at startup is the issue, loosening the shell under acceleration.
Thanks Bob. I stuck a Q-tip down in the center and a little grease or oil showed up on it. I will try what you said and clean it without disassemby first and then if I have to, will disassemble it. Now that you mention the inertia at the start being the issue, I remember I tightened up the belt a few weeks back and maybe that changed something just enough to show up this issue.
