- Mar 18, 2011
- 243
Just a wild shot but you didn't have the mill in reverse, did you?
No.
I could but once you go keyless, you never go back!You could use a keyed drill chuck and be done with it!
The outer shell is in two pieces, which separate next to the knurling. Look closely to find the joint there. You will need to make a split plate to clamp on the smooth cylinder between the two knurling sections to stop it from turning in a vise. Then you need another clamp to grip on the wider shell knurling. Right hand thread, but often/usually/always takes a lot of torque to break it free. With luck, you might be able to loosen it with two strap wrenches, but I wish you better luck than I have had. Watch our for losing the bearings when it comes apart! The Rohm chuck is similar to an Albrecht chuck to work on. Here is an EXCELLENT step by step disassemble, clean, lube, reassemble tutorial article written by 'Mikey' here on Hobby Machinist on rebuilding an Albrecht chuck, though posted on another site many years ago. It is better than the instructions from Albrecht and others.
