- Jul 29, 2014
- 2,728
Nice. How do you use the story bar?
Thanks.Nice. How do you use the story bar?
Thanks. Yours looks great and was a huge inspiration for making mine. I started out planning to make one exactly like yours, but then I figured I've got the scrap and the time, so let's play.Nice job. I see having the 4 with the 8 and the 3 with the 6 looks more normal than what I did. I only made one plate so I put the six with the 8. Looks kinda funky like I made a mistake as only two sides of the 6 line up with the 8.
2 inch center hole. I already had a set of 5c collet blocks that would do up to an inch. I wanted more capacity. That's why the set screws are so long. I was gonna get another set of shorter screws but they didn't get in the why so I, uh, didn't.Nice job, Ed.
What size did you make your center hole? Mine is a skosh over an inch, but it would be an easy matter to mill bigger if I necessary.
Regards
The set screws are exactly half into the octagon and half into the hex so I can get a square onto the lip of either one. I had to mill a half moon relief with a flat bottom so I could drill/tap the holes.So it looks like you have enough of a lip on the 6-sided section to still place a square in front of the set screws. I'm assuming made yours out of 1" stock?
I actually have a pretty good selection of set screws, so it was not difficult to scavenge enough for two that would recess on each plate. With 1" stock, countersinking would not have been necessary.
Regards,
Oh, very nice! I see that, now. Great idea!The set screws are exactly half into the octagon and half into the hex so I can get a square onto the lip of either one. I had to mill a half moon relief with a flat bottom so I could drill/tap the holes.
