- Dec 30, 2018
- 73
I've bought and tweaked several similar X-Y tables ... probably of a lower initial quality than the one you're looking at. If nothing else, the "dials" were really poor and it had a lot of backlash. Hope this one works well for you. My main concern would be with the X and Y motions. They look a bit limited - maybe 200-250mm X motion, and half that in Y?
Your estimate on the travel is spot on: 225mm for x and 150mm in y.
This is a little bit more than what I have on the mini mill: 215mm and 100mm. So far I have not run into any capacity problems on my mill's x axis, but the 100mm on the y limited me a couple of times so the extra 50mm will definitely be an improvement.
I think the best option would be to ask them to get one for me so that I can take a look at it in person.
Options over here are damned limited, so you have to make do with what is available...
