Rust
Martin W
Mar 26, 2014
1,506
I had bought a bunch of taper shank drill bits a while ago. They were a little rusty so I soaked them in some rust remover. What a difference. Here is one 2-1/4” bit after 20 minutes
Cheers
Martin
Holy cow is right...they’re only 3/4” smaller diameter than my lathe chuck! :D
Holy stamped ,my dp would have a problem with that thing.
What can I say, I like heavy equipment and it’s usually cheap.
The 2-1/4" and 2-3/4" bits have 5MT shanks. The only machine at the moment I can use them is my Lathe, which most times a boring bar is better. Most of the rest have MT#3 shanks which I can use in the Progress #3 drill press.
I am looking at a Radial arm drill that has a #6 MT but I am still trying to figure out how to get it home reasonably priced. It weighs more than the roll off truck can handle.
Cheers
Martin.1B296F8E-42D0-41F8-B1D7-5FFF9BAE18A3.jpeg0AD72038-3DE3-4162-8E2D-ADD9759C04D9.jpeg
Cheers
Martin
What brand rust remover are you using? I have tried several over the years and have not found one yet that does that good of a job. Every one I've used leaves a black coating where the rust has been removed.
